1980 F-36 with spongy foredeck and flybridge floor
The balsa coring is wet, delaminated and rotten in places. Has anyone found a suitable way to repair this condition?
repair
Yes! my wife bought me a Dremel for Xmas so here we go, I'll let you know how it goes..
F36 ~
SHES SOLDDDDDD
SHES SOLDDDDDD
soft areas
Did a west system restore years ago on a carver, was aok on the front deck where an anchor was mounted.........currently doing one on my f36 flybridge maybe five sq ft. .....I have cut two 8 inch acess holes behind the helm seats to clean out the mess.....then i will mix the west system epoxy up & soak 1 inch sections of nylon line & 4x4 sections of fiberglasss & force these new "Bridges" into the envelopes of fiberglass........West sytems reccomends a book put out by "Goiguion" or some spelling like that....It shows various methods & theories on how to go about restoration of areas........I will cover the two 8 inch holes with round access plates to coordinate with the color of the deck so it will not look like a fix.........I'd like to try expanding foam but the warping / craking of the decks due to expansion in a consealed area concerns me.....plus if you get the faom anywhere its not wanted & it dries it can only be removed via sanding
WE HAVE A GREAT FIX FOR BAD BALSA
WE HAVE IN STOCK AND HAVE USED TWO NEW PRODUCT FOR FIXING BALSA MUSH AND IT IS A QUICK EASY LIGHT FIX. AND SOME OTHER FIXES FOR COVERING THE CUT MARKS.
GIVE US A CALL
BEACON MARINE SUPPLY
OR E MAIL ME BOB@TROJANBOATS.NET
1215 547 8853
GIVE US A CALL
1215 547 8853
