Looking for a Chromalox Heater or just the switch
jwrape
Post by jwrape »
My Chromalox Wall Heater's picture below thermostat switch died. It is keeping the heater from coming on. I have it hardwired on or off to work but want to fix it correctly.
I would like to fix it or replace the switch or the entire heater.
Let me know what you have or can get me to fix this.
Here's the switch
79' Carver 28' Mariner
davidsmith
T stat
Post by davidsmith »
Try grainger Part#3UG98 or 3UF40. Close fit
1977-F36
22`Aquasport
1969 18` Donzi 2+3
jwrape
Re: T stat
Post by jwrape »
davidsmith wrote:Try grainger Part#3UG98 or 3UF40. Close fit
Great Thanks, i will check it out.
jwrape
Post by jwrape »
Wow 3UF40 is the exact one, but it's discontinued, but the other one will work perfectly.
jwrape
Post by jwrape »
Oh man, when I went to buy it, Grainger said it was discontinued too. Any more suggestions?
Here is the replacement Teel brand part number TEE3UG98-3 and you can buy it from these folks. Better call them first and make sure they have it. Good luck.
Edit: It looks like they're out of stock right now, so call them, maybe they can order or locate one for you. :D
http://www.mmimarine.com/mmi/index.php? ... anu_id=615
g36
switch
Post by g36 »
grainger lists this one as an alternative and there is of stock on their website #2YU46 the temp specs are a liitle different but shouldnt be a problem
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
