26ft ?
jenkins
26ft ?
Post by jenkins »
Finally got to the marina where the boat is kept now have more info, its a 1971 26ft.would love to know where to find an owner manual.also i cant get water to the sinks.Thank for the advice so far will be checking for the carb monday
jon_e_quest
Post by jon_e_quest »
Not 28'. Early 70's F-26. Maybe 1971-1972
Current Boats:
1962 18' Chris Craft Cavalier
Former Trojans:
1972 F-36 Tri-Cabin
1976 F-26 Express HT
1978 F-25 Express HT
jon_e_quest
F-28?
Current Boats:
Former Trojans:
1972 F-36 Tri-Cabin
randyp
Post by randyp »
That's a 25 ft. F-26 had a longer cabin profile, slimmer side windows and a split front cabin front window. Now for your plumbing problem. Most likely either a leak in a hose to the faucet or off the pump from the water tank. My F26 cold water side runs from the tank to the pump to the line that feeds the head sink and then splits to a tee fitting that leads to the galley sink. On the 26 there is a removable panel under the head sink vanity that gives you access to the hose and split off fitting to the galley sink. If your pump runs but no water check the actual faucet. Mine get plugged once in a while with small crud from the bottom of the tank. Some faucets have a strainer in the valve. I removed these and no more problems with no water at the faucet.
Hope that helps.
Randy P
1977 F-26 HT
"Blue Heron"
randyp
Post by randyp »
jon-e-quest set me straight. It's an F-26. The one-piece front cabin window led me to think it was an F-25, but the info and pics of his former F-25 showed me the error of my ways. Again, this forum comes through with the right information.
Randy P
1977 F-26 HT
"Blue Heron"
