lunaire air cond system
Hi again guys !
Can anyone tell me if parts are available for this old system ? I think i need a new switch control
1978 f32
Jim
Jim
air cond controls
just took the old style system out of my 78-F32 still have all the parts what is it that you need, I may be able to Help you
just for fun
Re: air cond controls
why was it taken outMrsluggo wrote:just took the old style system out of my 78-F32 still have all the parts what is it that you need, I may be able to Help you
1978 f32
Jim
Jim
and by the way my name is Jim alsosweet E mocean wrote:why was it taken outMrsluggo wrote:just took the old style system out of my 78-F32 still have all the parts what is it that you need, I may be able to Help you
1978 f32
Jim
Jim
Re: lunaire air cond system
I replaced my Digisette II controls with this product. Easy install and great features.sweet E mocean wrote:Hi again guys !
http://www.coastalclimatecontrol.com/
Sherman
'90 10m Midcabin
'90 10m Midcabin
Hey Mrsluggo i will be interested in a phew parts from that unit !Mrsluggo wrote:just took the old style system out of my 78-F32 still have all the parts what is it that you need, I may be able to Help you
1978 f32
Jim
Jim
You can usually repair the old unit cheaper then replacing it Get an estimate from a qualified service technician. You stated that the units were shot. What does that mean? Do they do anything when you turn the units on? A bad control panel, bad compressor low or no Freon, bad pump, or any number of other problems could keep the units from running properly. The AC units that Trojan installed are good systems and shouldn’t be trashed without an inspection by a qualified person.
Gerry
1979 F36 Twin Chryler 440's
Well I just had the AC unit in the cabin replaced yesterday and the installer said that the AC voltage to the boat is only 100 volts. He suggested not using the new unit until the power is addressed...
Could low voltage cause the compressor to die on an AC unit?
It seems odd that both my AC systems had the compressor go at once...
If it is the power do you think I have any recourse with the marnia?
- TADTOOMUCH
Low voltage
Yes,
Low voltage will make your compressor heat up and possibly burn out the compressor motor. Without the proper voltage everything will run hotter than it should.
Boat Name: A TAD TOO MUCH
