carburetor gasket
TADTOOMUCH
carburetor gasket
Post by TADTOOMUCH »
I am replacing the gasket between my carter AFB carbs and the manifold on my Chrysler M360 engines. The carb kit came with a four hole gasket for each throttle plate but it binds up my throttle plates and they won't open. It also came with a square opening gasket but the intake has four holes for each throttle plate in it. Which gasket is correct? Can anyone help me?
Boat Name: A TAD TOO MUCH
Check out page 19 of 59. It shows that the square gasket can be used. Also, checking with my local parts man, his books show a square bore gasket being use as well. Hope this works for you. Do you also have a angled spacer plate that you're using on this set-up?
http://www.arnolt.com/articles/carterafbtuning.pdf
