318 oil pan
fpawn1
318 oil pan
Post by fpawn1 »
Have to change oil pan on a 318--can it be done without taking motor completely out--the boat is a f-32
gjrylands
Post by gjrylands »
You will need to raise the engine. I used an "A" frame to lift the 440 in my F36. Once the engine and trans was lifted, I put 2 - 4 x 4's across the hatch opening and lowered the engine onto the mounts on the 4 x 4's. I was then able to get under the engine to remove the pan.
Gerry
1979 F36 Twin Chryler 440's
captainrob1985
318 oil pans
Post by captainrob1985 »
hey all
does anyone know if automotive oil pans are the same as the marine engine oil pans as i am having trouble finding marine ones.
Rob
wowzer52
Post by wowzer52 »
The oil pans on my 351's are 8 quart. Try calling Cook Engine Inc. Portland Or. 503-289-8466. They can answer any marine engine question you may have.
1975 F-32 "SIMPLY BLESSED"
Boaterguy
Re: 318 oil pan
Post by Boaterguy »
fpawn1 wrote:Have to change oil pan on a 318--can it be done without taking motor completely out--the boat is a f-32
Just curious, I have a 318 in my F25... why do you have to change it, and what should I be looking for on mine? I am a newbie to Trojan ownership.
1975 F25
318 RH
Sea La Vie
Re: 318 oil pans
captainrob1985 wrote:hey all
Rob
They will work. However, most marine oil pans are cast aluminum, keeps them from rusting and that some manufacturers call for an extra qt. or so in the marine application, external coolers, remote filters, etc.
You can use a steel pan. I have one on my starboard engine.
willietrojan
Post by willietrojan »
wowzer52,
What hp 351's do you have 233 or 255hp?
What kind of cruising speed do you get?
Spanish Fort, Al
Looking for 33 International
gjrylands
Post by gjrylands »
There is another difference between an automotive oil pan and a marine pan. Because the marine engine sits at an angle the oil pans shape is different. The bottom of the pan is made at an angle so the oil doesn't pool at the back of the pan. As mentioned, it also has a larger capacity.
Gerry
captainrob1985
boater guy reply
I have to replace the pans because thisboat was abandoned by its previous owner and water got in the oilpans and they cracked in the winter. a shame as she is a goregous boatbut now they areboth getting rebuilt, this shouldn`t be a problem for most owners
Rob
wowzer52
Post by wowzer52 »
Willie, I have 233 hp (2bbl) and cruise just on a plane at 17 knots at 3200 rpm. with full tanks and use 15 gph.
8kts=1600rpm=7gph again with full tanks.
6kts=1200rpm=3.5 gph
willietrojan
wowzer52,
That's about what I am getting between 16.5 and 17 knots @ 3100-3200
Spanish Fort, Al
captainrob1985
thank you wowzer52
Cook Engine had 1 they are shipping it. i will keep you posted on the project
Rob
