1977 F32 Bridge Enclosure Help
Tuck
Post by Tuck »
i just put my enclosure on this week (pain in the azz), but it's not right, it appears. granted, the previous owner never used it, and it sat in storeage for years and years, but i thought it would fit better than it does.
anyhoo...the snaps are all lined up, etc. but the question i have, specifically, is how does the rear piece go into place? inside the rail or outside?
if i place it on the outside, the 'door' won't zip. if i place on the inside, i have too much slack in it, and it doesn't look right.
does anyone have photos of theirs that they can post to give me an idea?
thanks in advance
Terran
1986 Silverton 40' Aftcabin
Terran
(former 1977 F-32)
My back canvas goes outside the rails, when I use it and snaps on the over hang above the cockpit.
If the canvas was stored for any length of time, especially if it was folded (big no-no :roll: ) it will have shrunk up, and it'll be a bear to get on. Perhaps wetting it throughly then trying will allow you to get it on?
I think each set-up may be different, dependent on the fabricator.
g36
Post by g36 »
you might try this if you will adjust the support arms or straps(not the pivots on the sides but the ones on the corners or the front 2 straps that clip to the boat by your light)that attaches to the boat for the bimini top it will allow the whole top to pivot thus raise or lower and this may be enough to make up for the difference of height needed to make this fit.
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
jwrape
Post by jwrape »
I swear they should pu pull straps on the ends of the windows on my rear enclsures so i can get the loops over the hooks. As it is now I use channel locks to pull them down most of the time.
79' Carver 28' Mariner
Peter
Post by Peter »
it is also much easier to put the canvas on when the canvas is warm rather cold and stiff. Another trick is to start all the zippers, then do the snaps, then go back and zip the zippers up all the way.
