Manifold and Risers Needed
And I'm looking for a quick and precise answer... :wink: :)
1982 F36 with original 460 Fords. I need to locate manifolds, risers and hardware for a buddy. This should be fun...part Chrysler, part Ford.
Thanks!
willietrojan
Post by willietrojan »
Spanish Fort, Al
Looking for 33 International
No good. Trojan used adapted Chrysler manifolds for their Ford engines when Chrysler no longer supplied their engines for marine use.
It's hybrid system of sorts...
Thanks just the same though Will.
willietrojan
You might try these guys
http://www.chryslermarineparts.com/
Spanish Fort, Al
Okay, I just need the risers and gaskets. Below is a pic of what the riser looks like. Thanks.
ready123
Post by ready123 »
looks pretty close to item 4492257K on the chrysler marine site
Michael and Will, thank you both, you're right Michael, that does look like the needed part! I missed it the first time...
Thanks again!
I sse you found what you need but hear is some other ideas
If you need manifolds http://www.oscomotors.com/catalog/catalog50.asp
And here is a neet idea put chevy manifolds on the ford
http://www.keitheickert.com/detail.aspx?ID=342
