leaking 1986 11m sedan
edt
Post by edt »
Have had major problem with leaking around all windows and the rear of the salon where the rear curved windows are. Have recaulked most of windows which has helped, however still getting leaks in rear of salon behind l couch. Is this a problem on most international sedans
edt
Post by edt »
Still haing an issue with the leaking windows, I have cleaned out as much old caulk as possible and recaulked with 5200 and still have major issues with eaks mainly on the port side main windows and the curved rear windows. Any suggestions would be greatly appriciated
there wa a similar issue with the 10 Meter series SEDANS awhile back and if I recall correctly, it was determined thge water was coming in from another spot, perhaps around the air intake vents (side vents, not the stainless grille areas) and then running down.
Perhaps someone else can shed some light on this issue?
DALE
Post by DALE »
edt wrote:Still haing an issue with the leaking windows, I have cleaned out as much old caulk as possible and recaulked with 5200 and still have major issues with eaks mainly on the port side main windows and the curved rear windows. Any suggestions would be greatly appriciated
I HAVE 88 10.8 METER,ALSO HAVE LEAKS. TOOK OUT FONT SIDE WINDOWS AND RESET. HELPED BUT STILL LEAKING SOMEWERE. CAULK USALLY DOESNT HELP UNLESS YOU REMOVE AND REBED. PLEASE HELP WITH ANY SUGGESTIONS GOING CRAZY
MattSC
Post by MattSC »
Here's a link to an article by a marine surveyor, he mentions in his article about the curved front window section being prone to leaks. Hope it helps http://www.yachtsurvey.com/boatreviews/ ... 8meter.htm
