Raritan Electric Head Switch/Push Button
dollarbill
Post by dollarbill »
What type of switch do I use for my Raritan Electric Head Switch/Push Button. I have one that has gone bad. I ask this because I think it is 12V and AC compatible. I think
Jersdevil
Post by Jersdevil »
If you remove the switch it should have the specs some where on the switch body, voltage, amperage etc. this will tell you what you need.
Hank Newman
"Winsome" 1979 - F30 Clean Machine
First Sergeant, U.S. Army Retired
Co-Owner Don Snyder
Just wanna confirm you are looking for this for a Raritan -- my '79 still has the original 'Monomatic' recirculating electric head, with a 'momentary on' push button switch, and I have a part number for it - Blue Sea 8200... (100% 12V DC, its wired up in a way that it works even if battery switches are off).
g36
Post by g36 »
if your switch is activiating a solenoid such as with a raritan crown head the switch doesnt have much current on it. the solenoid is carrying the load. the switch is just activating it. if so just about any momentary switch will be fine. all a switch is doing is making and breaking a contact inside of it. yes pull the old one and look at it but its not something to stress over finding the exact switch.
if you do have the solenoid might make sure that thats not what is bad instead of the switch
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
gjrylands
Post by gjrylands »
The push button switch you should be using is the extra heavy duty switch that is rated at 35 amps @ 12 volts. West Marine sells the switch, model # 270876 which comes with a black water-repelent cover. Cole # M-626.
Gerry
1979 F36 Twin Chryler 440's
