440 issues
gofish103
440 issues
Post by gofish103 »
worked on a friends 36 this weekend. he was having problems with the motor stalling at low rpms.
we've changed all fuel filters, plugs, cap, rotor and the intake choke spring and metering rod.
starts fine, idles in nuetral, but when you put it in gear it stalls. if ya pick up the idle a little it seems ok. Need advice!!
Danny Bailey
Post by Danny Bailey »
It is possible there could be something on the prop causing it to be excessively hard to turn, or the transmission clutch plates could have been overheated causing them to stick and making the transmission hard to turn.
g36
Post by g36 »
what kind of idle speed are you trying to obtain?
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
gofish103
Post by gofish103 »
rpm's are in the 700 range. trying to dock the boat is the issue, trying to keep the motor running and docking
ready123
Post by ready123 »
gofish103 wrote:rpm's are in the 700 range. trying to dock the boat is the issue, trying to keep the motor running and docking
Are you saying the engine does not keep running while shifting in and out of gear while docking?
Danny Bailey
Incorrect timing can also cause low torque at idle.
Check your timing as mentioned. If it's OK, check to see if all cylinders are firing by running the engine to temp, then pull one plug wire at a time from the distributor. If the cylinder is firing, you will note a drop in RPM or performance, you should hear a difference. Reinstall the wire and move on to the next one. If no change is noted when you pull one of the wires, that cylinder is not firing. Had this issue before and turned out to be 2 bad new plug wires after a tune-up.
