screw turns in neutral
rooferdave
Post by rooferdave »
my port drive turns in neutral, starboard does not, any suggestions?
Shift cable needs adjusting, not letting transmission come completely out of gear ?
gettaway
Post by gettaway »
does it turn slowly or as if it were in gear?
rbcool
Post by rbcool »
If your not moving through the water, it's probably a shift cable adjustment. Try disconnecting the cable then moving the lever arm by hand. If you don't find "still" neutral, might be a seal issue.
Ron 8)
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Upper Bay, Chesapeake Bay
Normal 99% of the time , is it turning slow or can you stop the shaft with a peace of wood ? if so your OK . the reason one side rotates and the other stays still ,is one of 2 things tighter clutches on the 1 gear box and/or less drag on the shaft on that side
Post by Paul »
Mine does this in neutral when the trans oil is cold. Once the oil warms up the slow rotating stops. Can also stop with a piece of wood as Paul says.
Mine did it . It needed adjusted, nope on the wood.
rooferdave
turns slowly, when in the water the boat moves in neutral, does the same with no cable on it, as it is winterized I guess I have to wait till it warms out or is there a test if I dissconnect the drive? Thanks for the help all!
If it spins slow in neutral ( goes faster in gear ) that is not abnormal some will and some won't . and the boat may move a little I have one in the shop that if you turn the input shaft by hand the output will turn from clutch drag ( new clutches set to spec) .
You most likely have normal clutch drag the colder the fld the more drag . go hop on 10 other boats and bet half of the may do the same .
put you car up in the air start it up in neutral and watch the wheels turn .
rooferdave
ugh, lets not get into cars/truck trannies just blew a tranny and transfer case in two separate trucks in the last 2 weeks
pk
Post by pk »
rooferdave wrote:ugh, lets not get into cars/truck trannies just blew a tranny and transfer case in two separate trucks in the last 2 weeks
Don´t you have the real stuff in your cars over ther?? :shock:
The real stuff ????
pk
Post by pk »
The real stuff ????
Yeah, trucks like Volvo and Scania? I myself drive a Volvo FH Longhauler with trailer on. I have a full Autobox on that one, worked nice for 3 years now. Gonna have a new truck firstcoming autuum. If you are interrested I can provide you with lot of pics from my truck and the roads where I work.
Audrey II
Post by Audrey II »
Sounds like you have a loose screw:)
A couple of years of therapy should fix you up.
1996 Trojan 440
pk
Post by pk »
What if the fluid / oil in the box is from a wrong type? Or maybe the oil is contaminated by "something"?
