10 Meter A/C Strainer
- tsawyer
I attemped to clean out the strainer on my A/C system.
The gaskets are shot and I now can't keep it from leaking.
The only markings I found are on the inside of the top lid and it says SVS 4.
A little internet research tells me it's a Groco SVS strainer. There are 3 models, however, and I'm not sure which one I have.
Anyone know which model was used on the 10 Meter Mid Cabin?
Thanks.
Thanks.
Tom Sawyer
Rum Floater
1988 10 Meter Mid Cabin
Fort Lauderdale, Florida
Rum Floater
I noticed recently when looking for new Grocos' for my boat, the different sizes seem to correspond with the different sizes of inlet/outlet barbs. Maybe if no one here has the exact model #, measure yours and compare to the specs for the one you found on internet. But I'm sure someone here has the answer.
Ron
Ron
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Upper Bay, Chesapeake Bay
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
I think it is the 750, I saved the old package and left it in my toolbox. One tip, the 2 nuts don't really provide the seal.... the center "wingnut" does that.
I found that out after talking to Groco, mine was leaking and I only had the canter hand tight. It needs to be tighter than that.
- tsawyer
Ok, thanks for the tip.
I ordered a couple of maintenance kits for the SVS750 directly from Groco.
I thought for sure I was going to break the glass. It was turning out to be that kind of a project.
Alas, I didn't. At least not yet.
I'll give it another go when I get the parts.
Tom Sawyer
Rum Floater
Rum Floater
I have a fitting drilled into the lid of my strainer (Groco?) that has a ball valve and a garden hose quick disconnect fitting attached.
This way I can do a fresh water flush of the circulating system after each use and have the ability to do a really quick & easy reverse flushing if i pick up debris in the strainer while underway.
This is an inexpensive retrofit that would be good top do while you have the unit apart.
How's that work in gettin jellyfish out. I know someone that Sucks them up a lot.
You dated her too?
RWS, now that's just nasty, very funny but nasty
, and no ! I didn't date , took her to the barn but that's not datting
But does the back wash work on jellyfish ? I travel with a old fart that needs his ac and pool, restaurant and cable tv you know the type and is always sucking up those stinking jellyfish
