Swim Platform Oil ??
Lawman
Post by Lawman »
Hey guys
I'm going to strip and re-finish my swim platform hopefully soon (if the weather gets better). I'm lookin' for some feed back on Teak oil, Danish oil, Tung oil. I bought Sikkens Cetol to redo me brightwork but don't want to worry about the swim platform being slippery, Any feed back would be appreciated.
g36
Post by g36 »
i use bristol finish on my platform thats what was on it when i purchased and it is very durable and holds up very well to the use of the swim platform on my boat. i also use the cetol on the other exterior wood and like it as far as the durablitiy and being able to scuff it and add new coats. the bristol finish when wet is slippery but i have a custom piece of marine carpet that i snap in place on the platform that matches my cockpit carpet so i dont have an issue. i very much like the look of the teak so this is only put out when we are actively swimming etc for the day . i do understand the slippy issue.
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
The regular Cetol Marine is not (typically) slippery - just don't use Cetol Gloss over top of it. I have been using it on my platforms for (amost) 20 years now without incident. I haven't used oils for years, other than lemon oil for interior surfaces.
If you have fears about grip, you could also use some sand or silica for a bit of DIY 'non-skid' (apply one coat of your desired finish, sprinkle sand or silica over it while still wet, let it try, then apply additional top coats).
[*EDIT* I just saw the previous post (guess it appeared while I was writing my feedback)... I have never found the Cetol to be slippery, but I guess peoples' experiences may vary.]
jimbo36
Post by jimbo36 »
lawman, I too have used cetol on swim platforms for years without slipping issues. :) The key here is to strip and sand the teak thourghly and wipe it down with acetone just prior to your first coat.Teak is oily and the acetone wipe down removes the layer of natural oil from the surface grain which greatly helps with the adhesion of the first coat. :wink: I hit it with a minimum of 3 coats, than every year I sand lightly with 320 and recoat once. If you do this you will never need to strip and recoat again and your swim platform will get continual oooh's and ahhh's 8) jimbo36
rbcool
Post by rbcool »
Good advice Jim :wink:
Ron 8)
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Upper Bay, Chesapeake Bay
wowzer52
Post by wowzer52 »
Cetol
1975 F-32 "SIMPLY BLESSED"
jimbo36
Post by jimbo36 »
wowzer, Lookin goooooood! 8)
jimbo36
Lawman
Platform
Post by Lawman »
All great posts, thanks for the feedback guys. Now if I can get the wife to start sanding!! :shock: :lol:
1973 F30 Clean Machine
' Goomar '
(Italian for 'my mistress')
Post by Paul »
I'm with wowzer on this one. My platform gets a fresh coat of Cetol every couple of years. And yes, my wife is the one who does it. :D
wowzer52
Post by wowzer52 »
I took my swim platform off and took it to a cabinet shop and they ran it through a drum sander. Was that cheating?
jimbo36
Post by jimbo36 »
Not in my book, just very clever :lol:
