onan 6.5 mcck question?
lynneraye
Post by lynneraye »
does the onan genset I have in the 85 international has a charging system and the fly wheel has no magnets...please reply need to know
lynneraye
10 meter international sedan bridge
Can you be a clearer on what you need to know ? :wink: :arrow:
g36
Post by g36 »
are you asking if it charges its own battery? my onan 6.5 in my 78 f32 does.
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
lynneraye
Post by lynneraye »
does the generator have a separate alternator?
lynneraye
Charging system is usually part of the generator windings. No separate alternator (yes on bigger units)
Look at the control panel. You should see 3 fuses the right is for the charging system., but some guys remove them , as they have their bank charger wired up to the gen battery.
Billd
Post by Billd »
I've got a 1988 10.8 Convertible with the 6.5 MCCK onan. There is one set of windings that makes the power and throught the control panel some is converted to D.C. to charge the battery (as well as supplying the D.C. power to run the unit). If you have no output (bad solenoid or relays usually) from the windings the power required to keep the unit running isn't there and it will simply shutdown as soon as you stop cranking it. If the unit continues to run but isn't charging the battery it is usually the charger diode that's cooked. A wiring diagram will show where it's located (approximately).
Another option is to simply put a small 120V battery charger by the genny and whenever the genny is running the charger will look after the start batttery.
Bill
lynneraye
Post by lynneraye »
everyone... thank you for answering the question at hand- rebuilt the genset, found by the internet and manual everything needed to know.
painted the bottom and waxed the hull besides putting the zincs on we put new props on. WE GO IN THE WATER ON FRIDAY! have a great season!!!!
lynneraye
