Anyone know
Anyone know
On my 10.8 my holding tank is under the foward birth. The hose that enters the top of the tank goes through a round panel that looks like it either spins on or is in place with some adhesive. Anyone know if this should just pop out or does is thread into the top of the tank?
On the top of mine There is a 6 inch round inspection plate That screws off. But no Hose
going through it
Ron.
going through it
Ron.
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Upper Bay, Chesapeake Bay
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Same here. A simple inspection plate cover. Just unscrews. Am wondering if the hose you describe is a vent hose ...might very well be.
That looks like someone moved the inlet fitting and used that "plastic weld" stuff. I've never seen home type pvc plumbing for discharge, sure hope one of those fittings don't vibrate loose
Ron
Ron
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
We've had this discussion a while back with his set-up, so far it seems to be working for him.rbcool wrote:That looks like someone moved the inlet fitting and used that "plastic weld" stuff. I've never seen home type pvc plumbing for discharge, sure hope one of those fittings don't vibrate loose![]()
Ron
Stripermann2 wrote:We've had this discussion a while back with his set-up, so far it seems to be working for him.rbcool wrote:That looks like someone moved the inlet fitting and used that "plastic weld" stuff. I've never seen home type pvc plumbing for discharge, sure hope one of those fittings don't vibrate loose![]()
RonIf it works, it works!
Good point...... it looks new
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
