Cleaning the Bilge
risctaker
Cleaning the Bilge
Post by risctaker »
I got a closer than I wanted to inspection of the bilge in "Basket Case" (I think I found Jimmy Hoffa). Short of buying a few gallons of marine "bilge cleaner" has anyone come up with a good environmentally friendly substitute?
aka "Basket Case"
383 Chryslers 280 HP V-Drives
Lincoln Harbor Yacht club
Weehawken, NJ
There are some cleaners which say they're biodegradible, Simple Green, etc...with that being said, one can fill the bilge with degreaser and water, turn off the bilge pumps and go for a ride. Bumpin' and turning to slosh the cleaner around.
Then of course, you have to turn the pumps back on... :roll:
I'm gonna power wash the inside of my engine room when I pull it.
k9th
Post by k9th »
Stripermann2 wrote:There are some cleaners which say they're biodegradible, Simple Green, etc...with that being said, one can fill the bilge with degreaser and water, turn off the bilge pumps and go for a ride. Bumpin' and turning to slosh the cleaner around.
And this really works well - I have done it on prior boats with great success.
Tim
"SeaDog"
1979 36' Tri-Cabin
Dawn works well too !
Mine was N A S T Y when I got her. They even left the old sperk plugs down there, fasteners, wire ties, can tops, etc.
Of course the bilge pump was attached with a couple of wire nuts. . . .
priceless!
Simple Green works great and so does greased lightening,
Allen Sr
Post by Allen Sr »
I've used Mr. Clean before and it worked.
2011 Trojan Rendevous
Solomons Get Together 2011
Ocean City 2012,2013,2015
JGedridge
Post by JGedridge »
I swear, after cleaning my bilge I have to be the bilge king LOL!!! jk
I scrubbed all bilges in my boat with dawn and other cleaners and I ended up painting the whole bilge. Thats what you might want to do after you clean the bilge. Regular light grey porch paint will work!
Clean bilge is everything when selling the boat too!!
Joe
Struts and Rudders
Post by Struts and Rudders »
I have had great success with the Krud Kutter Professional Cleaner...found at Walmart on the home paint isle. Cheap and effective.
Spraying on to a dry engine room floor is the seems to be the key.
They also have great mildew and mold remover and inhibitor.
SRD
F36
Whatever you can't get out with sloshing bilge cleaners and sprays, try hand cleaner with pumus and a scouring pad. Gets the most greasy and stuborn oil stains you can throw at it. When I first got the old girl the sloshing cleaner wasn't quite enough. Soon after trying bilge cleaners several times, I removed the genny for a rebuild and the holding tank. This gave me access to the bilge from stem to stern. Put hand cleaner in a dish soap bottle which made it great for squirting where I wanted it. A scouring pad, stiff brush and a whole lot of elbow grease got everything out squeaky clean. Rinced with garden hose, and wet vac to remove. Boat smelled like oranges for weeks!!
kevinz
Post by kevinz »
Shop Vac is the ticket!! suck the water out, along with the wire ties, nuts, ect.. and then dump properly (wifes rose bush that gets you when you cut the lawn, neighbors pine trees, ...)
:lol:
JGedridge
Post by JGedridge »
LOL AAAAAAHAHAHAHAHAHAHAHA :D :D :D
after some touch up paint during the refit . . . .
a little dab will do ya !
BobCT
Post by BobCT »
I'm amazed by how much "stuff" in the mid cabin is in the engine room on the express.... holding tank, A/C, freshwater pump, HW tank, etc.
ok, my useless observation of the day.
risctaker
Post by risctaker »
Thanks for all the great tips guys!. Hey RWS - looks like you have been spending some time down in the mechanical spaces. Nice clean machine! Do you sleep down there?
aka "Basket Case"
Weehawken, NJ
