Page 1 of 2
has anyone tryed poly glo
Posted: Wed Mar 30, 2011 5:40 pm
by mr elevman
Posted: Wed Mar 30, 2011 6:00 pm
by alexander38
Seen a few boats after it was on for awhile. They looked yellow
Posted: Wed Mar 30, 2011 7:24 pm
by Wes
Maybe they were made in China.
poly glow
Posted: Wed Mar 30, 2011 7:31 pm
by BobCT
I've read bad things about it, like peeling and yellowing as well. It looks great going on, I've seen it firsthand but ultimately makes a mess.
I also read that mop-n-glow is the same stuff which makes sense.
poly glo
Posted: Wed Mar 30, 2011 8:26 pm
by davidsmith
My F-36 was very chalky. We tried compound and wax, lasted about three months chalk was back. Put 5 coats of Poly Glow on last spring and it still looks like it did the day we put it on. It dosent have the shine that wax does but the chalk has not come back and it is easy to apply. Also very easy to keep the hull clean, nothing seems to stick to it. Going to put one coat on this year.
Posted: Wed Mar 30, 2011 8:27 pm
by g36
i use it and have been for the last 3 years. my boat isnt yelllow and there is no peeling at all. i will continue to use it. if you dont put it on according to the instructions then there might be some problem with adhesion but as of yet i have none. i have many complemnets .
Re: poly glow
Posted: Wed Mar 30, 2011 8:31 pm
by RWS
BobCT wrote:I've read bad things about it, like peeling and yellowing as well. It looks great going on, I've seen it firsthand but ultimately makes a mess.
been there, done that on a 22' Grady White.
Looks GREAT for a while.
I was truly impressed.
Once it starts to go, it goes BAD.
Run Away !
Unless you are looking for a quick sale.
Posted: Wed Mar 30, 2011 9:52 pm
Re: has anyone tryed poly glo
Posted: Wed Mar 30, 2011 9:53 pm
by rossjo
mr elevman wrote:has anyone tryed poly glo
No.
But I think Paul is experienced with Poly GRIP ....
Posted: Wed Mar 30, 2011 9:54 pm
Ross That was low even for you
I expect that from Tony but you ??
Posted: Wed Mar 30, 2011 9:57 pm
by rossjo
Well - from your pix, your(?) teeth look great ... so inquring minds begin to wander ...
Posted: Thu Mar 31, 2011 4:14 am
by alexander38
Hey hey! I didn't say a thing about poly-grip , I could've taken shots on this one, the king is gettin cut on because he popped at the all you can buffet
is that what you excepted ?
Posted: Thu Mar 31, 2011 6:17 am
by foofer b
Gotta chime in. My super structure was very badly oxidized. I compounded, buffed, waxed and swore and it was still chalky. I put poly glo on my boat three years ago and it still looks great with no recoating. I do store my boat under cover, but most of ya'll do too, at least six months of the year. Dirt does just rinse off
Posted: Thu Mar 31, 2011 1:37 pm
by risctaker
I was able to spend some time last Fall with a fiberglass restoration pro who does this stuff for a living. He both told me what to do then gave me a demo on a badly oxidized 40 year old FG hull. First he sanded the entire hull with 220 grit in a high-speed orbital sander (the sandpaper does NOT harm the gelcoat). Next apply a liberal amount of 3M heavy duty fiberglass rubbing compound using the same high-speed orbital sander but this time with a heavy buffing pad. Finally finish with a high-quality marine paste wax using a standard power buffer. When done my girlfriend could have applied her makeup in the reflection of the hull.
Posted: Thu Mar 31, 2011 2:03 pm
by g36
sigh
