12VDC Gasoline Transfer Pump
rossjo
Post by rossjo »
Anyone using or recommend a good gasoline transfer pump?
Need:
  • > Gasoline Approved
    > Ethanol Tolerant
    > External (to boat)
    > 12VDC
    > Low pressure
    > High Volume
jddens
Post by jddens »
Not sure of your application.....I have this pump. I fill 5 gallon containers at the gas station and bring them to the boat. This pump works great for that but it is very light duty......but the price is right..............John
http://www.kotulas.com/deals/batteryope ... nsfer-pump
1998 Kawasaki ZXi 1100
I use this set-up. The mechanical pump works well..and fast.
I have a hitch hauler on my Suburban. I fill her up and off load at the dock and wheel down to the boat. Pretty easy as the hitch hauler isn't too far off the ground for me to unload.
http://www.tank-depot.com/productdetail ... t=2403WPQD
risctaker
Post by risctaker »
For those of you who are filling up portable tanks and taking them to the boat, aren't you pretty much guaranteeing that you will be feeding corn-gas to your boat? I see some of you have older boats which have engines that are not adequately protected against the effects of Ethanol.. Or are you getting gas with the good old MTBE rather than ethanol somewhere?
aka "Basket Case"
383 Chryslers 280 HP V-Drives
Lincoln Harbor Yacht club
Weehawken, NJ
rossjo
Post by rossjo »
Both good options - but I need something that can run a lot of fuel through - so its needs to be 12VDC, and doesn't need any sort of tank.
May be looking at an electric fuel pump for an inboard boat of some sort.
Any others? Didn't someone on here work for a company that makes these?
jddens
Post by jddens »
risctaker......here in CA there is plenty of non-corn gas available.....so far....
k9th
Post by k9th »
rossjo wrote:Both good options - but I need something that can run a lot of fuel through - so its needs to be 12VDC, and doesn't need any sort of tank.
Ross - I am Engineering Manager at Fill-Rite which has made 12VDC, 24VDC, and 110/220VAC fuel transfer pumps ranging from 12-30GPM for more than 50 years. Let me know what you need and I can probably get you a refurb unit.
Tim
"SeaDog"
1979 36' Tri-Cabin
rossjo
Post by rossjo »
Tm,
Yes -it was you! I thought I remembered somebody in this product line.
  • > 12VDC
    > Low pressure (<10psi)
    > Medium Volume (75-150GPH?)
    > 3/8" or 1/2" NPT female inlet/outlets OR 3/8" Full Line Barbs
    > Explosion and Leak Proof
    > Gasoline (and Ethanol) rated
    > Easy to mount to a panel
Thanks Tim!
k9th
Post by k9th »
Ross -
I am posting a link to the Grainger catalog which lists about 70 of our pump products. Find what will best meet your need and let me know which one it is. We refurb warranty returns and I can usually get them if we have any - and we usually do.
http://www.grainger.com/Grainger/wwg/se ... sst=subset
Tim
"SeaDog"
1979 36' Tri-Cabin
would just setting up a elec gas pump work as well ? like the one used on the onan 6.5 ? :arrow:
rossjo
Post by rossjo »
Tim,
The FILL-RITE FR1614 looks like it would work, but it has 3/4" outlet fittings (1" inlet). I plan to use 3/8 fuel line and filters. Is this too much to step down to?
Tony,
yes - I suppose ANY engine gasoline fuel pump would work like Sierra replacement for an electric fuel pump for a fuel injected Mercury inboard). That's what I had planned to use - but Tim may have an off-the-shelf unit that is approved for external Fuel Transfer.
rossjo
Post by rossjo »
Did some more digging - and I think I'm going to go with this Mr. Gasket Electronic Fuel Pump (35gph & 7psi):
http://www.summitracing.com/parts/MRG-12S/
Tim - I appreciate your offer and help, but I believe your products are overkill for my application.
k9th
Post by k9th »
Ross -
They are more than you need and the one you picked out is not explosion-proof. I am sure the one you chose will work well.
Tim
"SeaDog"
1979 36' Tri-Cabin
:shock: what did I miss :?
rossjo
Post by rossjo »
Tim,
Thanks again - I'll try this and see how it works.
