Calling 36'TriCabin Owners - How much Bottom Paint?
I'm planning the haul-out and bottom work now. How many gallons of bottom paint are you guys using on your tri-cabins? I'm not going to make a big deal out of this like taking the bottom down to the gelcoat, I just want to powerwash, sand , re-coat and drop back in.
aka "Basket Case"
383 Chryslers 280 HP V-Drives
Lincoln Harbor Yacht club
Weehawken, NJ
aka "Basket Case"
Weehawken, NJ
It should use about 1.5 gallons. (2 gallons)
My good friend and I split 3 gallons between my 32 and his 36 with paint left over...
2 gallons
So that would be 2 then
Cheap
that's an understatement.
see I'm just stating fact..
- aaronbocknek
