Do you check your oil with the engines running or not?? I've heard alot of different theroies
Ron
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Upper Bay, Chesapeake Bay
I've heard alot of debate over this. I took my Saturn to the dealership a few weeks ago and the mechanic told me should be checked when warm and running
Ron
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Be sure to have the winter air changed in all your tires as well...
aka "Basket Case"
383 Chryslers 280 HP V-Drives
Lincoln Harbor Yacht club
Weehawken, NJ
Not sure you can even check the oil with the engine running. Think somone is pulling your chain.
I used to have an admin assistant whom we told to "rotate the air in her tires". She came in one day and said she tried, but couldn't rotate the air, so she just let the air out of all 4 tires and the re-inflated them. Ouch!
You should check an automatic transmission with the engine/trans warm (drive it several blocks) ...
Talked to a couple of friends who are currently GM and Ford dealer techs and they confirm checking oil with engine off on thier product. Also have searched the internet re the Saturn and I couldn't find anything on oil check with engine running.
Whoever made that statement needs a rubber room! Never heard of such BS in my life to check engine oil with it running!
2011 Trojan Rendevous
Solomons Get Together 2011
Ocean City 2012,2013,2015
