Engine specs for 351 Windsor motors! Help please
Posted: Wed May 25, 2011 2:48 pm
by 30'Express1975
Hey guys,
Im going to be adjusting my carbs Friday and I need to know my tune up specs or engine specs for what the motors should be. Can someone please help me out here?! I would greatly appreciate it!
25 people look, someone HELP
Posted: Thu May 26, 2011 4:13 pm
by 30'Express1975
25 of you guys have looked at this. Can someone please help me out with this? I need help!
Posted: Thu May 26, 2011 8:07 pm
Mercruser ? marine power ? crusader ? 2 barrel ? 4 barrel ? HP ? can make a difference
If your just setting the carb , I usually adjust the idle speed between 550-650 more of a by feel thing then spec. as some engine like a little more or less rpm for smooth running .
Posted: Thu May 26, 2011 9:51 pm
by Stripermann2
Be more than happy to help but help us first. Year, and HP rating would be a good start. Two or four barrel carb...like Paul said.
Posted: Fri May 27, 2011 6:39 am
Posted: Fri May 27, 2011 4:42 pm
by rossjo
PleasureCraft Marine (PCM) 302/351 Manual
http://www.correctcraftfan.com/Download ... Manual.pdf
Compliments of Correct Craft!
Posted: Tue May 31, 2011 9:44 pm
by aweimer
Didn't hear back the brand yet.
What type of carb? I assume Quadrajet. You will need a TAC to connect at the engine. Set idle to 600rpm. Turn both adjustment screws in, only snug, NOT tight. Then turn each out 1 and 1/2 turn. Reset the idle to 600. Now adjust in or out until you peek the idle speed on each screw, then reset the idle when finish to your desired speed. 550-600 RPM in gear as the mercruiser manual says.
Good luck, there are some 4 barrel quadrajet you tubes that explain this pretty well too.
Posted: Tue May 31, 2011 10:03 pm
Don't think you will find a Q-jet on a 351 .
Posted: Wed Jun 01, 2011 7:18 am
by 30'Express1975
Thanks so much guys! You all have been a big help! Been trying to get this bad boy in order. Hopefully i can finish the job this weekend. I appreciate all the help!
351 Windsor
Mercruiser 233HP
Velvet transmissions
