Engine specs for 351 Windsor motors! Help please
30'Express1975
Post by 30'Express1975 »
Hey guys,
Im going to be adjusting my carbs Friday and I need to know my tune up specs or engine specs for what the motors should be. Can someone please help me out here?! I would greatly appreciate it!
"For Her Pleasure"
Detroit River
Downriver Boating Community
30'Express1975
25 people look, someone HELP
25 of you guys have looked at this. Can someone please help me out with this? I need help!
"For Her Pleasure"
Detroit River
Mercruser ? marine power ? crusader ? 2 barrel ? 4 barrel ? HP ? can make a difference
If your just setting the carb , I usually adjust the idle speed between 550-650 more of a by feel thing then spec. as some engine like a little more or less rpm for smooth running .
Be more than happy to help but help us first. Year, and HP rating would be a good start. Two or four barrel carb...like Paul said.
rossjo
Post by rossjo »
PleasureCraft Marine (PCM) 302/351 Manual
http://www.correctcraftfan.com/Download ... Manual.pdf
Compliments of Correct Craft!
aweimer
Post by aweimer »
Didn't hear back the brand yet.
What type of carb? I assume Quadrajet. You will need a TAC to connect at the engine. Set idle to 600rpm. Turn both adjustment screws in, only snug, NOT tight. Then turn each out 1 and 1/2 turn. Reset the idle to 600. Now adjust in or out until you peek the idle speed on each screw, then reset the idle when finish to your desired speed. 550-600 RPM in gear as the mercruiser manual says.
Good luck, there are some 4 barrel quadrajet you tubes that explain this pretty well too.
Aaron
____________________________
1975 36' Tri Cabin
"Keep it up!"
E-Mail : aweimer@comcast.net
Lake Erie, OH
Don't think you will find a Q-jet on a 351 .
30'Express1975
Thanks so much guys! You all have been a big help! Been trying to get this bad boy in order. Hopefully i can finish the job this weekend. I appreciate all the help!
351 Windsor
Mercruiser 233HP
Velvet transmissions
"For Her Pleasure"
Detroit River
