So I'm looking at picking up a Humminbird 385ci to replace my dying Humminbird Wide-eye... As the boaat is already in the water, can I get some suggestions as where to mount the transducer in the hull for the best reading? What location are the f-25 and 26 guys using?
re: Transducer mounting for F25
- hemijosh426
In the bilge is considered a through hull transducer and it can do very well. The original depth sounder is thru hull. New ones will have instructions on how and where to mount them in the bilge. I put the fish finder on the transom for more sensitivity in spotting fish, or in my case, bottom contour for finding dive sites.
MY CURRENT FLEET
2003 KEY WEST 2020 WA
1978 14' ASHCRAFT SKIFF
The hull of Trojans in solid FG (at least it is for the F26 and F25, and I'm assuming for the other models). That being the case you can mount a through-hull transducer on the inside of the hull. I used a healthy dose of clear "GOOP" and "spooged" the thing right on the surface of the hull in the engine compartment near as possible to centerline of the hull forward of the prop...basically on the starboard side about 1-1/2 feet back of the engine compartment bulkhead. It's a Garmin 168 GPS/Sounder and works pretty well.
Randy P
1977 F-26 HT
"Blue Heron"
1977 F-26 HT
"Blue Heron"
