RE Hydraulic steering cylinder
Sorry to start a new topic- could not find my old one and someone pm'ed me thru Bob asking about it. I have recieved my rebuild kit but have not the time yet to diginto her. Plus I need an adjustable spanner pin wrench with 3/16 pin . Any ideas where to get one?
MY CURRENT FLEET
2003 KEY WEST 2020 WA
1978 14' ASHCRAFT SKIFF
A ajustable tool for a boat fuel cap should work
http://www.iboats.com/Perko-Heavy-Duty- ... ew_id.5376
Most marine stores should carry them
This is the type pictured on the instructions page. http://buy1.snapon.com/catalog/item.asp ... oup_ID=602
However, the instructions call for a 3/16" pin size and 3/4" - 2" adjustable span, but in that size only 1-8" pins come with it. Will it really matter?
MY CURRENT FLEET
My question exactly. The SnapOn tool looks like it's designed to wrap around something cylinder shaped and help you rotate it. The one that Paul posted is for removing a cap or deckplate - totally different applications, needing totally different tools.prowlersfish wrote:do you have a photo of the part your tring to remove ?
gLAD YOU GUYS CHIMED IN. i BORROWED A TOOL BASED ON THE PICTURE SUPPLIED ITH THE REBUILD KIT. Here is the pic.
Here is the cylinder at both ends. Doesn't look like it will work on this cylinder.
Or the other end
Kinda looks like I need the type wrench that Prowlerfish pointed out, Here.
Perhaps I'd better make sure my seal and oring kit is the correct one. Cuz the piture for the spanner wrench aint right.
Or the other end
MY CURRENT FLEET
A LOT OF PATIENCE!!!!!!! I have seen our mechanics at work actually heat the tube up and use a hammer and punch to drive the cap around until they can get it to turn with the wrench. Then clean everything thoroughly no dirt, no nothing in it. At that point the cap should thread back in by hand most of the way. They are working on tilt cylinders for fork lifts though...........
2011 Trojan Rendevous
Solomons Get Together 2011
Ocean City 2012,2013,2015
I made one by getting a CHEAP open end wrench bigger than the diameter of the cylinder and drilling a hole in each claw that would match the position on the cylinder. The holes will be tapped for threads to screw in SS bolts the same diameter as the holes in the cylinder so the holes you drill must be the correct size for the tap to accomodate the right size bolts. The bolt only needs to protrude less than 1/4 inch. That size wrench will give you the leverage you need.
Harbor freight has a pin spanner wrench. I just has some hydraulic tractr cylinders rebuilt. I asked them how they got the packing gland out. Answer was bit vice and bit pipewrench and cheater bar. however it would leave marks that could be dressed down for looks.
pipe wrench however will not take out the pin plug though.
Last edited by larryeddington on Tue Aug 09, 2011 8:35 pm, edited 1 time in total.
