drain plugs
drain plugs
Does anyone know how many drain plugs the 1976 F25 has? I see one in the aft section by the tank but I have to think there are others. The bilge is full of sludge and I need get it cleaned it smells so bad i can smell it from inside my house!
Plug location
There should be a drain plug in the front, under the V-berth. If you boat is on the hard, and the bow is lower, it will drain most of the water. You may have to make sure that it doesn't get plugged with the "sludge".
1975 F25
318 RH
Sea La Vie
318 RH
Sea La Vie
