Mid cabin - transducer location
Posted: Sat Nov 12, 2011 5:27 pm
by BobCT
Can you guys tell me where you have your transducers installed?
I asked this over the summer and one of guys suggested near the inboard stringer/stb engine.
Airmar has suggested moving it forward and closer to the centerline. I was thinking of the mid cabin/under the center seat.
Wondering if that might be too low/ easy to hit.
Thnks
Posted: Sat Nov 12, 2011 5:59 pm
by koviak
Bob, this is where mine is located at the mid cabin area about 1ft. off the center line (starboard side)
before I cut a hole :)
Posted: Wed Nov 16, 2011 10:15 am
by BobCT
You lift up the center mid cabin seat cushion to access it?
It will essentially be across from the AC seacock with the stringer in between, correct? Seems like a good spot, certainly nothing in front of it to create turbulence.
thanks
Posted: Wed Nov 16, 2011 6:01 pm
by koviak
That is correct.
