TRI CABIN UNDERWATER EXHAUST SYSTEM
aaronbocknek
Post by aaronbocknek »
some of you have wanted to know what the tri cabin underwater exhaust system looks like. here are two pics, a third will be added to show the 'idle hull side bypass'.
this is the exhaust collector system and through hull (5") bellows. the small muffler to the left of the round collector system is the hull side bypass.
this is the underwater 'clam shell' assembly. facing forward is to the right of the pic, the 'jet holes' that face aft, are to the left.
i'm curious to know if other tri cabin owners, those with the engines under the salon, have the same set up.
aaronbocknek@gmail.com
Commissionpoint
Post by Commissionpoint »
Cool. I've never really seen that setup before. I knew it was out there, just never saw a close up of it. I would imagine its relatively quiet compared to the traditional arrangement. Is there some kind of safety check valve or flapper in there or is it like a Merc outdrive, torn bellows = sink?
1978 F-32 "Eclipse"
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
Commander 351 Ford (PCM)
1:1 Borg Warner
Tri-Guy
Post by Tri-Guy »
I have most of the same system. I do not have the muffler or diverter, I only have the 5 inch exhaust under the boat. The system is very quiet, also scary hole in bottom of the boat. My boat never seemed to have the other half of your system.
k9th
Post by k9th »
Mine is identical to yous Aaron.
Tim
"SeaDog"
1979 36' Tri-Cabin
that's a very cool system, where the gen-set exhaust exit ?
aaronbocknek
alexander38 wrote:that's a very cool system, where the gen-set exhaust exit ?
the genset exhaust is just forward and up from the idle over flow through hull fitting. i'll take pics of this today if i remember my camera. follow the hose from the 'lift' muffler, that's for the genset. personally, the system scares the crap out of me. i check the neoprene bellows on a bi-monthly basis. one split and it's good by tri cabin. there is no way to shut that massive 5'' hole off. to top it off, if you need to change out exhaust hoses and/or 90 degree elbows, the boat has to be hauled. water is always in the system. from what i understand, trojan's mind set was two fold.
1. save money and space for the traditional exhaust run and muffler system, and 2. the exhaust that 'jets' out the clamshell, actually lifts the boat for faster and easier plane. it also, from what my mechanic tells me, sucks the exhaust out of the engines keeping back pressure lower. it's still an odd set up.
aaronbocknek
Tri-Guy wrote:I have most of the same system. I do not have the muffler or diverter, I only have the 5 inch exhaust under the boat. The system is very quiet, also scary hole in bottom of the boat. My boat never seemed to have the other half of your system.
TRI GUY, what year, make and model is your tri cabin? i'd (we) would love to see pics of your system. and believe me, that 5'' hole with no way to shut it off scares the crap out of me. i'm always checking those neoprene bellows for signs of cracking etc...... is your collector the same? i actually have a spare collector that the PO left onboard. why i have no idea. but, if i remember, i will take some detailed pics of it and post it here on this thread. again, i'm curious to know about other underwater exhaust systems my fellow troganers have......
Id be worried to about it...but it does seem to be a sound system, there's times we wished ours was underwater due to the station wagan effect, but underwater exhaust for the Gen set would be great ...
rbcool
Post by rbcool »
Mine is the same, except my "Pan Flute" is slightly different.
Ron 8)
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Upper Bay, Chesapeake Bay
Commissionpoint
alexander38 wrote:Id be worried to about it...but it does seem to be a sound system, there's times we wished ours was underwater due to the station wagan effect, but underwater exhaust for the Gen set would be great ...
As would I worry, but its really no different than an outdrive I suppose. I have had lots of those, in fact there are two complete 1.51:1 units in my garage right now. I think that like an outdrive, you make sure the bellows are in good shape and you change them immediately if there is the slightest question in your mind as to thier integrity. I wonder if a 4" CPVC ball valve (CPVC is rated at 180F at 100PSI) would be a good addition to this system. Like an intake seacock but on the exhaust side. Trick woul be how to integrate it to the exhaust thru hull I would imagine. Maybe have a 4 inch gate valve braised to the damn thing? Custom casting? I dunno. Bilge water alarm at the very least. Won't help if you are away, but might if you are sleeping on board and something goes very wrong with it. I'm willing to bet that system has put more than one boat on the bottom. I know that torn bellows on outdrives certainly has.
Last edited by Commissionpoint on Sat Nov 19, 2011 10:29 am, edited 1 time in total.
1978 F-32 "Eclipse"
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
1:1 Borg Warner
rcamaine
Post by rcamaine »
Mine is the same setup as Aaron's. Having only got the boat back in August I only looked at the bellows once.
Where can one expect to find replacement bellows?
Thanks.
1980 36' Tri-Cabin - "Jeaga" - Maine
aaronbocknek
here are some more pics of the underwater exhaust system. i'm curious to see/know about other versions of this system. the bellows, from what i understand, might be replaced with a bellows system from trident marine systems. i've put in an email to them, but have not heard anything.
here is the top view of the spare collector the PO left onboard.
underside view of collector
exterior view, starboard side, idle/low speed bypass port, genset exhaust is in the right hand corner. the small thru hull in between is the salon a/c condensate overboard drip port. no dripping into the bildge.
ultra closeup of starboard bellows/collector/small rubber muffler for low speed/idle exhaust.
now, this is the setup that will be removed over the winter. for some reason, the PO installed a second holding tank for the aft head. this setup limits access to the shaft log and extends OVER the port exhaust system with only 1/4" clearance! when the engine starts, the exhaust bellows needs to flex up and down and with this current set up, it hits the holding tank assembly causing the boat to shudder. i can't wait to get this POS out of there.
Allen Sr
Post by Allen Sr »
All that green on the side axhaust fitting would also give me some concern as well, but thats me.
2011 Trojan Rendevous
Solomons Get Together 2011
Ocean City 2012,2013,2015
is all that bonded ? Aaron ...
JGedridge
Post by JGedridge »
Mine is EXACTLY the same. I do like it because it is semi quiet and it rumbles sometimes. I do miss the straight through exhaust systems like on my old boat and the Sea Rays.
Joe
btw: the Sea Rays have a different underwater exhaust system. I like theirs better however, but what can ya do? :lol:
