Trojan 26
Trojan 26
Hello. I am new to the Trojan forum.
I am possibly interested in buying a 26 Trojan express. Does anyone have any first hand knowledge of this model? Any information would be very helpful....Cruising speed, top speed, ocean going capabilities and or general specs of the boat, etc. Do folks on this forum recommend this boat or possibly another Trojan model. I live in SoCal and will be taking the next boat out in the ocean on a regular basis. How does the boat/hull compare to other top brands i.e. Bertram, Skipjack etc?
Look forward to reading responses and recommendations.
THANKS!!
THANKS!!
Welcome to the forum . I would not call the F26 a ocean going boat But there are few 26 footers I would . Can it go in the ocean ? sure but you have to pick your days . Its a good all around boat
I have a F36 and I still pick my days
The F-26 is a great boat depending on your specific needs. Based on Great Lakes boating I can tell you the following: it cruises between 18-20 mph @ about 1.3 miles per gallon, top speed is 28 mph, handles well in 3-4 ft waves (Lake Erie waves close together), 4-6 ft can be a handfull, moving fast thru a following sea no problem, slow in a following sea the boat gets pushed around and is hard to handle.
Generally these boats are solid however it depends on the condition its in. I would recommend that no matter what model boat you should find that will suit your needs, have it surveyed by a professional before you purchase it. You'll have a better idea what your getting into.
Hope this helps.
Hope this helps.
- Beacon Bob
Performance Data for F 26 318 or 228 (not the V drive model 70, 71 )
1. Low Cruise 2500 RPM 13 MPH
2. Cruise 3000 RPM 19 MPH
3. Max Cruise 4000 RPM 28.5
Trojan did make a F-26 with T 140 Volvo Sterndrives 79' 80' Top speed was 35 MPH
jefflaw35 wrote:welcome im new too. paul i like that boat again, i think it needs an all black haul LOL
Jeff you have 2 Paul's here ( or more if you count me )
You have Paul and Paul - SW Ontario , Both have done great things with their boats
Trojan 26
Jeff post some pics of your progress and paint. I bought a 1978 F 26 F/B couple months ago and I am in currently getting her ready to fish out in the gulf. I have replaced every switch and installed brand new gauges apart from disconnecting and cleaning every other terminal and connection. The salt is bad enough on newer electrical terminations so you might want to think about that also. New bottom paint will be the next renovation then it's on its way to the big pond.
