AARon looks so calm at helm im scared of my new boat already
jefflaw35
Post by jefflaw35 »
:D
jefflaw35
Post by jefflaw35 »
:D
aaronbocknek
Post by aaronbocknek »
believe it or not, my nick name on the site for the tri cabin is the ''ss piersitter''. when phil and i were bringing her from the brokers marina to our home port, i ran over a crab pot that was in the middle of the channel and unmarked. WHAM----SHUDDER----AWFUL NOISES FROM UNDERNEATH THE PORT SIDE AFT. ended up 'tuliping' 2 of 3 blades on the port prop. lack of sheckels and time last year resulted in no repair,but, hopefully, this spring will be a different story. comfort level onboard is great, both phil and maccabee like the wider decks and the stable ride. now, i'm looking calm underway because i grew up with the tri cabin. docking is whole other ball of wax. i'm an absolute basket case when it comes to the tight quarters, however, mike kulp (trojan international neighbor) and his wife kathy are great at calming my nerves and this past fall took me out one warm afternoon to do some practice runs. THANKS MIKE!!!!
as for your dogs----BOSTONS RULE!!! i love all breeds of dogs, but bostons hold a very special place for me. something about those expressive ears and faces. our marina is the absolute most dog friendly of any i've been to. lots of open green space for them to run if they want, 126 boats, and 125 dog owners. and listening to the 2 chesapeake bay retrievers that live across the channel from my slip larking about in the water at all hours and temps, makes it a very good place to be.
and i love the parrot too!!! now that is just way too cool.
tri cabin aaron......
aaronbocknek@gmail.com
Mike Kulp
Post by Mike Kulp »
Aaron there will be more practice in the spring, you need to pull that boat and fix that wheel so we can burn some fuel.
Mike 1986 10 Meter mid cabin
Mike Kulp wrote:Aaron there will be more practice in the spring, you need to pull that boat and fix that wheel so we can burn some fuel.
X 2
X 2
x3
what size wheel do you need ?
aaronbocknek
alexander38 wrote:
X 2
x3
hi mike, thanks for the help. i will be calling on you and your first mate i think as phil's business (contractor/renovation/hvac/electrical) is really keeping him busier than a one legged man in an ass kicking contest.
tony, the original specs call for 20x21 with a 1.75" shaft. i believe that my wheels are 20x21. to be honest, i'm drawing a blank on that one. and that's not me. totally frustrated on that one.
aaron
3 or 4 blade ?
3 blade 20x21 1 3/4" let me make some calls...if I can find one laying around this Sh@@ hole marina I'm helpin' clean up I'll snatch it... you need port or stbd ? and rotation ?
1.75 shaft ?? no way , maybe 1 3/8 ? or 1 1/4 . The largest shaft size for most 20" props is 1 1/2 .
Recheck on that Aaron should be in your survey
aaronbocknek
prowlersfish wrote:1,75 shaft ?? no way , maybe 1 3/8 ? .
sorry bout that guys, i've screwed up on the shaft size. had an brain freeze moment for a moment. let me check back with my mechanic, but, i should have said they are 1 1/4" shafts.
aaron
Now that sounds more like it , you can always use a 1 3/8 or 1 1/2 with a bushing .
aaronbocknek
alexander38 wrote:3 blade 20x21 1 3/4" let me make some calls...if I can find one laying around this Sh@@ hole marina I'm helpin' clean up I'll snatch it... you need port or stbd ? and rotation ?
hey tony, had a senior moment there for a minute.... the shaft size is 1 1/4, i believe, i will recheck again w/ my mechanic tomorrow. i can't believe i don't have this info off the top of my head. very bad sign. i'm also unshure as to the rotation. the port prop is the one that's fraked up.
aaron
ok I'll hold..... :lol:
aaronbocknek
prowlersfish wrote:Now that sounds more like it , you can always use a 1 3/8 or 1 1/2 with a bushing .
that's what john said this morning when i spoke with him. he did mention the bushing. my brain is a jumble these days for various reasons.... paul, thank you for your patience. tony, you too....
aaron
