looking for wiring harnesses
antlr-king
Post by antlr-king »
i have a 79 trojan express 30. i need the 2 engine wire harnesses. im pulling the engines in the morning. when i unpluged the power today from both i could hardly get the 2 plugs apart. they were badly corroded. i would need both ends. the main wire harness that plugs up to the short wire harness that is connected to the solenoids. anyone know where/if i could find these. thanks...
http://i413.photobucket.com/albums/pp21 ... val005.jpg
1979 30' trojan express
What's the engine application? Chrysler, Mercruiser?
If for the Chrysler Marine, yes they are available.
Number 1 and 2 are engine wiring harnesses. There are a couple of different part numbers, dependant on which you need. Plus the solonoid and switch side pigtails should also be available. Pm me for info.
antlr-king
oh right on. i have chrysler 318's. i will pm you
