Cabin damage and rat terds, nice!
jefflaw35
Post by jefflaw35 »
this looks good.
years of trickling water from what appears to be a window leak has deformed the fiberglass. you could see it thro the headliner.
guess the cabin is first. needs more than i thought, good winter project.
Alex!! the coolest guy I havent met and know nothing about, Thanks again!! Wifey (Amanda) said WOW what a great guy, you are just like us. We thank you truly. If you ever need anything at all just let us know!!
More stinky stuff is out, this boat is infested with mold and stinch!!
jefflaw35
Post by jefflaw35 »
from Alex darn photobucket didnt select the right pic.
looks look your going to need some ply-wood and bleach water. And you'll need to find where the water came in from 1st....and you all are welcome...
aaronbocknek
Post by aaronbocknek »
morning tony, looks like you and i are keeping first watch, again. maccabee and i just got back from our morning walk. wet nasty snow. he was like, ''whf? snow? on MY grassy areas? RUBBISH!!!'' short walk though. in anticipation i walked him super early yesterday. his 'launch code' went off a few yards down the street. quick clean up then he raced me home. he's now tucked under the electric blanket w/ phil probably until 0700.
jeff.... looking at your water damage at the cabin side windows.... trojan window frames were notorious for this. i suggest you completely remove the frame and look at the 90 degree edges and at the very front and back, under the frame. i will bet you there will be water burn through from years of sitting water. that can be repaired, but, it needs to be addressed. then you can rebed the frames. or, diamond seaglaze in seattle can fabricate new ones for you and might save some stress further down the line. the new frames are much better and drain faster. just a suggestion.
aaron
aaronbocknek@gmail.com
trojanmanXS
Post by trojanmanXS »
lol nice to see jeff, mine was the same when I got her. I refabbed all the cdx that went around the inside of the window like yours.wasnt hard at all, but like someone mentioned best to get the cdx that was between the fiberglass dug out and replaced as best you can while you have it opened up. I did mine and have had no leaks after the repair ,ratturds you say ? lmao I had a RAT/BAT HOTEL in my cabin cleaning that all out was the worst a little tip if you plan on saving the headliner in the boat DO NOT PRESSURE was down there!!!. I spread that filth all over trying that. luckily I have a 17yr old son so I had 7 - 5gal buckets of water and as one got nasty the boy would dump it and hand me the fresh pail. took a couple days but ended up looking and smelling pretty good when I got done . good luck !!!
jefflaw35
Post by jefflaw35 »
No saving this headliner, she crumbled when I touched it lol. I Goya post another pic when I get back to see if you guys can tell me what this price of plywood under my cushion area is for, it's in a very odd place and screwed in at an angle
32pacemaker
plywood shelf
Post by 32pacemaker »
that is where your table bed cushion get stored...... big project there i was there a year ago with the early bee also a f 26
jefflaw35
Post by jefflaw35 »
Yea I pulled that piece back out of snow cover scrap pile last night, I'm gonna put it back
foofer b
Post by foofer b »
Bump
MY CURRENT FLEET
2003 KEY WEST 2020 WA
1978 14' ASHCRAFT SKIFF
foofer b wrote:Bump
WHY ????? x 5
I know why..... :P
jefflaw35
Post by jefflaw35 »
alexander38 wrote:I know why..... :P
x2 :wink:
