what is this plywoods purpose?
does this out of place sheet of plywood serve any purpose? does your boat have it to?
When in place its to suport the lower V-berth cushons ( it has fallen down ) Looks like some of the suports maybe missing
the bottom of what was you set/bunk
I think you're on the right track there Jeff; looks like there was an attemp made to do something in there, perhaps storage. It always amazes me how people can just slap things together like that without exercizing any real thought, or maybe it was an OEM shelf that fell. Looks like you have some upholstery to do also. Glad someone is bringing her back to the glory she deserves. Can't wait to see her done. Good job Jeff.
not to get ahead of you but when it comes time to remove that fabric /plywood on the walls next to the berth be careful and you will see that at the top theere is a small 3/8"plywood that is setting atop a glassed in stringer try and save these pieces as it is arched to form fit this location. use the original to trace out the replacement , my portside was to far rottted but was able to use the starboard side as a template and then a little extra trimming and they fit right back in there snugly. careful this is the area I removed mine to find the mice lair!!!!! they had quite a time making a nest in this area. "same for the larger panels its alot easier to unscrew these to use as templates you will get alot better fit then pulling some numbers and making multiple cuts . get some pics if you get time during it .
bare with me guys as i am trying to learn your termanology with some things. i plan on replacing every peice of wet wood i can get to. this plywood peice has to be some half ass storage like D said. it didnt fall down, its screwed in like that, i agree and see no reason why i cant trash it and design my own extra support rails for the bunk and make my storage even larger, there is alot of bad wood in here, i am trying to be careful as this is gonna take longer than i thought. im labeling and bagging every peice for refab. the front window trim is being very stubborn and i dont want to break it, have to learn how to slow my ADHD down on this one LOL
i beleave i removed these peices you speak of last night, the were in real good shape still and came out nicly. the plywood backrest wall is rotted bad though, there coming out today after the boat show. i have to be careful because origanal fabric is glued in and its hard to seetrojanmanXS wrote:not to get ahead of you but when it comes time to remove that fabric /plywood on the walls next to the berth be careful and you will see that at the top theere is a small 3/8"plywood that is setting atop a glassed in stringer try and save these pieces as it is arched to form fit this location. use the original to trace out the replacement , my portside was to far rottted but was able to use the starboard side as a template and then a little extra trimming and they fit right back in there snugly. careful this is the area I removed mine to find the mice lair!!!!! they had quite a time making a nest in this area. "same for the larger panels its alot easier to unscrew these to use as templates you will get alot better fit then pulling some numbers and making multiple cuts . get some pics if you get time during it .
planning is everything and make sure you only remove what you have to..
The cell phone or digital camera are great tools for this sort of thing. Shoot as many pics as you can of an area before dismantling, it'll make it a lot easier for reassembly. Especially when it's this big a project and it may be some time before you get back to assemble a section.
