run it like a trawler ????
will crusing at low rpm's save on fuel
1973 f32 twin 318's raw water cooled
My experience is that it will definitely save on fuel, but you obviously sacrifice time. If you are like me and love to be on the water and the trip is a large part of the goal, then it's a good trade-off. If the destination is the goal and time is of the essence, then it is a bad deal.
Tim
"SeaDog"
1979 36' Tri-Cabin
"SeaDog"
1979 36' Tri-Cabin
Only if you are running at or below 'hull speed' (= 1.34 x square root(water line length)). That is as fast as you can push through water without the boat trying to climb on top of it (ie plane). Hull speed is the fastest you can go without starting to burn power trying to also lift.
I don't have the number near me, but for the F32 waterline length is about 28' I think. So about 7 knots (around 1500 rpm probably) is going to be the fastest you can go for the least fuel.
Good point and thanks for bringing it up.captainmaniac wrote:Only if you are running at or below 'hull speed' (= 1.34 x square root(water line length)). That is as fast as you can push through water without the boat trying to climb on top of it (ie plane). Hull speed is the fastest you can go without starting to burn power trying to also lift.
Tim
"SeaDog"
1979 36' Tri-Cabin
"SeaDog"
1979 36' Tri-Cabin
We run at hull speed alot 8 knots, most when we're just doing lazy trips...you know trips with no real place to go...but if we have to be at way point on set time the speed is set for that...but no faster than 17 knot that's the sweet spot...for 1 to 1.
My "Sweetie" is 16-18
Ron
Ron
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Upper Bay, Chesapeake Bay
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
What does running a gas engine at 1000-1500 RPMs for a extended time do to the carbs, and spark plugs?
-1995 350 express
with big blues (454 Crusaders)
-2011 Caroling Skiff J-14 (Tohatsu 30hp four stroke)
-1996 Sea Ray SeaRayder jet (Merc 90hp)
-1990 BeachCat 20. Fiberglass pontoon (2013 Merc 60hp big foot)
I have put alot of thought into this subject. I purchased and repowered my single screw F30 express last fall and have not launched yet. My solution was to buy a Floscan.
http://www.gandermountain.com/modperl/p ... SHOP_94165
The hour meter is a nice bonus for keeping track of use on the new engine.
1976 F30 Model 303
- 1995 390 express
kevin im thinking if your engines are tuned and running properly there should be no problem running at 1500 plus rpm. 1000 will barely be above idle. not sure but i think your year and engine type should be throttle body fuel injected. they look like carbs with spark arrestors on.i was told they are a great fool proof system if thats what u actually have.
