Water Heater Replacement
abkeywest
Post by abkeywest »
My water heater decided to spring a leak this past weekend. Would a small 6 or 10 gallon 120v water heater from Lowes or Home Depot work? I do not need the heat exchanger option and have easy access for replacement. I am asking this mainly due to price, $250.00 versus $700.00.
1983 33' Carver Mariner
hmc
Post by hmc »
yes AS LONG AS ITS NOT IN ENGINE ROOM ( FUMES )
f boat ( glass )
TROJANS !!!
abkeywest
Post by abkeywest »
Thanks hmc!!!
After I posted I did a little more research and found the same thing. It is forward of the port engine in the engine compartment. For safety I will replace it with a marine water heater.
I know you get what you payfor but, Seaward brand water heaters are some what less expensive than Raritan does anyone have any thoughts?
k9th
Post by k9th »
Unless you are going to live onboard and have it turned on all the time, I am thinking the cheaper one will work just fine for occasional use. My water heater is used only five months a year and then only an average of two days per week. The rest of the time it is turned off.
Tim
"SeaDog"
1979 36' Tri-Cabin
mitch
Post by mitch »
ok
