Question About Shorepower
The Dog House
Post by The Dog House »
This is my first boat with shorepower. Today I turned the VHF radio on while the shorepower was on and the VHF fried. Needless to say I won't be turning any electronics on anymore unless the shorepower is turned off first. I thought the AC system would be isolated from the DC system. Is it normal to have to turn off the shorepower first before using the DC electronics, or is the boat not wired correctly? Thanks for any insight you can provide.
Former boat: 1971 Trojan F26
Allen Sr
Post by Allen Sr »
NO! Its not normal at all! I would say you have a very serious problem! It also could of been a freak accident. Take a multi meter and check the voltage at the plug for the radio. Should be reading in the 12 - 13 volt dc range depending on what state of charge your batteries are in.
2011 Trojan Rendevous
Solomons Get Together 2011
Ocean City 2012,2013,2015
k9th
Post by k9th »
I cant imagine anyone cross-connecting AC & DC. I'm voting for freak accident or strange coincidence.
Tim
"SeaDog"
1979 36' Tri-Cabin
gettaway
Post by gettaway »
I'm voting coincidence as well, you would have burned the boat to the water line by now if the two were connected, at the least, you would have certainly blown the shore power panel breaker
1984 Silverton 37C
Silver Lining
Scott
Agree with above. Also, was your charger turned on? If so, turn all DC power off and check what the output voltage of the charger is. You should be able to do this at one of the batteries.
Big D wrote:Agree with above. Also, was your charger turned on? If so, turn all DC power off and check what the output voltage of the charger is. You should be able to do this at one of the batteries.
X2 and check the voltage at the VHF too with the shore power on and off . Then check it on the AC scale on the meter to see if your getting any ac cross over
The Dog House
I'll check the voltage at the VHF connection and see what it is. The battery charger turns on automatically when shorepower is connected, so maybe the battery charger is putting out voltage that is too high. I'll let you know what I find.
For my own knowledge, the AC system and DC system are totally separate? The only connection between the two would be the battery charger? The boat has been modified many times by many owners over the years, and I'm still trying to figure out what all of the wires behind the panel connect to.
Thanks for your help.
The Dog House wrote:... The battery charger turns on automatically when shorepower is connected.... the AC system and DC system are totally separate? The only connection between the two would be the battery charger?.....
Charger turning on automatically is not a good idea. Are you saying there is no breaker or ON/OFF switch for the charger so you have the option to shut it off if you want?
Electrically, except for grounding, AC and DC is separate, however in a typical older installation, the electrical panel containing the two system wiring has little room and no isolating panels for separation and shorts can occur.
And yes, no telling what a previous owner has done. Check your voltages.
mitch
Post by mitch »
ok
ready123
Post by ready123 »
mitch wrote:Hey, ya are missing the point. 110 volts AC connected to a 12 volts DC battery? DC power supply is battery, NO AC on battery, Radio blew up by self? YES
It may not be as simple as that... suppose boat ground for AC and DC are connected and the shore power has a leak to ground leg...still think DC is only 12V :?: :?:
mitch
Post by mitch »
ok
