fuel tanks
glen Masters
fuel tanks
Post by glen Masters »
Hi all, new owner of a 1977 32 flybridge express. I need some info. The boat is being shiped in a week or two. I need the dimensions of the rear gas tanks. the boat has 4 tanks Im talking about the 2 that are mounted across the back. thanks
Glen Masters
jddens
Post by jddens »
Welcome to the forum........bunch of F32 owners on here....Someone will help you out.............
1998 Kawasaki ZXi 1100
gettaway
Post by gettaway »
Hi
I have a 1977 F32 with the rear tanks, mine are round, I'll measure them later tooday when I go down to the boat,
1984 Silverton 37C
Silver Lining
Scott
DAVIDLOFLAND
Post by DAVIDLOFLAND »
The original round tanks in my F-32 were about 60 gallons each. I had new ones (rectangular) built that are about 90 gallons each. I measured the available space, then left some room on top of eact tank to be able to access connections, sending units, etc.
Yanmar 6BY3-260's
k9th
Post by k9th »
Welcome aboard
Tim
"SeaDog"
1979 36' Tri-Cabin
rossjo
Post by rossjo »
Welcome aboard.
Like David said, the original cylindrical tanks are abut 60gal each.
Your tanks may or may not be original from 1977 ... l
Welcome to the site .
BTW I believe he is looking for the dimensions not the capacity . Hopefully Gettawake will be able to measure his dimensions
glen Masters
the tanks that are in it are 60 gal rectangle. Im trying to get some new ones located before the boat gets here so I can replace them. and cut down my yard time.
Glen Masters
rossjo
Post by rossjo »
Out of town, or I'd measure mine for you.
Not sure I'd buy tanks without measuring your own boat, as there could be modifications or additions in the way that affect the layout/placement. You may even want to drop from 4 to 2 tanks, unless you're planning on long range cruising. Storing 4 tanks full of ethanol tainted fuel will only make more fuel go bad (2-3 months).
Ross has some good points .
glen Masters
Yeah I had Planned on only using 2 tanks
Glen Masters
rectangle ? I was thinking the stern tanks were round . The may have been changed .
what shape are they F32 owners ?
ready123
Post by ready123 »
Round 60 gallon here
prowlersfish wrote:rectangle ? I was thinking the stern tanks were round . The may have been changed .
On my '85 F32, the front are 50 gallon rectangle and the rears are 60 gallon round.
A couple of threads...
http://www.trojanboats.net/wforum/viewt ... fuel+tanks
Fishblues
Post by Fishblues »
Here you go, I put two new Moeller tanks in my boat last year and love them. 58 gallons each, 1976 Trojan F32.
http://www.moellermarine.com/aftermarke ... ent_tanks/
