Has anybody tried to repair wobbly taff rail hinges? I was thinking of boring out the holes and using a larger roll pin. The trick is to make the center hole not too big or it will be wobbly again. My F32 has three gates and new hardware is expensive. This is my 29th season with this boat.
Taff Rail Hinge Repair
- aaronbocknek
Re: Taff Rail Hinge Repair
did i read that right? 29 fantastic seasons with your f-32? MAZEL TOV!!lakeguy72 wrote:Has anybody tried to repair wobbly taff rail hinges? I was thinking of boring out the holes and using a larger roll pin. The trick is to make the center hole not too big or it will be wobbly again. My F32 has three gates and new hardware is expensive. This is my 29th season with this boat.
agree w/ jeff. a machine shop should be able to take care of that for you.
Aaron you did read it correct--29th season. My wife picked a good one.
I got one of the rollpins out and reduced the OD of a new pin in the section where the center section rides and it is much better with minimum wobble.
