have tricabin any advice on getting the engines out
in the last post i said that after a 10 year lay-up both engines have antifreeze in the cylinders..gonna pull engines and was wondering does anyone have suggestions on how they got their engine out. the engines are in the aft cabin with wlaters vee drives.. thanks
- aaronbocknek
hi kevin, tri cabin aaron here. okay, if you have removed the aft bulkheads you should be able to 'crane' the engines out. trojan designed those bulkheads to do exactly that if necessary. another option, and this is from my mechanic, is to removed the risers and manifolds and break the engine down into its smallest components and lift the engine out the aft door that way. i would suggest, if you can, remove the v-drives too before doing that. when my mechanic john does a repower on an under the salon version of the tri, he almost never uses the engine removal hatch that is molded in above the headliner. he prefers to do the break down and reassembly method and has done so with great success.
just a suggestion. i cannot wait to be well enough to venture up there and help you with some of this stuff.
aaron in baltimore.
aaron in baltimore.
Kevin, I see you have closed cooling so the breakdown will produce a lot of stuff. Any idea how the antifreeze got into the engine? Not sure of your plans, but be sure to check all your cooling components including the heat exchangers, manifolds, etc. I think Aaron is referring to your velvet drives when he said v-drives. Your Walter V drives are on their own once unbolted. Hope your restoration goes well.
- aaronbocknek
you're right jimbo.... that's what intended to say. sorry, pre chemo brain.jimbo36 wrote:Kevin, I see you have closed cooling so the breakdown will produce a lot of stuff. Any idea how the antifreeze got into the engine? Not sure of your plans, but be sure to check all your cooling components including the heat exchangers, manifolds, etc. I think Aaron is referring to your velvet drives when he said v-drives. Your Walter V drives are on their own once unbolted. Hope your restoration goes well.
- aaronbocknek
