water tank gauge
fourreins
water tank gauge
Post by fourreins »
I have a 10.8 international and the fresh water tank gauge comes on (lights up when I turn the switch on) but the needle doesn't really move much. Do you think I have an issue with a float in the tank (sending unit)???? Any thoughts would be appreciated. Thanks
Landlocked
Post by Landlocked »
Don't know how similar the boats are, but my 1984 11 Meter Sedan doesn't have a float. It uses two 10 - 12 inch probes that go down into the water tank. They haven't worked for years. The needle will barely move, regardless of how full the tank is.
Lake boaters skip the salt...
1985 11 Meter Sedan
1972 Newman Bassboat
1990 Cyclone Jetboat
davidsmith
Post by davidsmith »
Take the probes out and clean them. If they are coated with crud or calcium they will stop working. We use them in cooling tower basins to keep the water level correct.
1977-F36
22`Aquasport
1969 18` Donzi 2+3
lawyerdave71
Post by lawyerdave71 »
Or I have a simple solution which I do all the time - you fill the tank and when the water comes shooting out, I know its FULL!!!
Captain Dave -
1978 F30 Flybridge Express
Vitaliy
Post by Vitaliy »
thats fairly much my method, seems to work every time, my tank probes dont work either and hoenstly could care less if they did
1974 F36 Tri-Cabin "Jorallyn"
