Port shaft strut feedback
Could i get some feedback on this please?
The port shaft engaged at idle gives a sound of what seems to me sounds like a bad bearing right where the strut is. Kind of like the sound of a well oiled drill bit going into steel, not super squeaky, but very similar to me. Gone after idle, no visible vibration in the shaft, slight in the motor between 2300 and 3000, gone after that all the way to full song.
I just launched last week and checked everything prior to. Any thoughts on what could I have missed? 1984 11M Express, twin 350 Crusaders
Thanks as always
James
Thanks as always
James
Have'nt done mine yet (but it's due), There is a special tool that allows you to remove the bearing while the shaft is still in but you'll have to pull the boat out in order to do it.
1973 F30 Clean Machine
' Goomar '
(Italian for 'my mistress')
' Goomar '
I wouldn't do it in the water either, been there done that, never again! Before hauling out, check engine/shaft alignment between tranny flange and shaft coupler. Get it right at that location first then sea trial. If it still happens, then go through the expense of a haul out. Personally I don't screw around anymore with pulling the bearing with the shaft in place. Given that bearings are typically in place for years before replacing, this is the perfect time to remove the shaft, send it in to be dialed, and prop to be tuned unless you know they have been done recently. That way, you eliminate all sources of vibration at once so you don't have to wonder why you're still getting a vibration after a new bearing install only to find out the prop or shaft were slightly off, and having to go through it all over again.
- aaronbocknek
i second the motion. short haul, swap out bearing after checking alignment and you're good to go. but, remember, the alignment MUST be done in the water as the boat 'sits' different in than out.Big D wrote:I wouldn't do it in the water either, been there done that, never again! Before hauling out, check engine/shaft alignment between tranny flange and shaft coupler. Get it right at that location first then sea trial. If it still happens, then go through the expense of a haul out. Personally I don't screw around anymore with pulling the bearing with the shaft in place. Given that bearings are typically in place for years before replacing, this is the perfect time to remove the shaft, send it in to be dialed, and prop to be tuned unless you know they have been done recently. That way, you eliminate all sources of vibration at once so you don't have to wonder why you're still getting a vibration after a new bearing install only to find out the prop or shaft were slightly off, and having to go through it all over again.
