FUEL TANK REPLACEMENTS F-32
Larrys78
Post by Larrys78 »
Does anyone know where and how much new alum saddle tanks are. replacing motors and thinking of changing the tanks also although the old ones :? don't leak any advise would be helpful
TANKS Larry
1978 F-32 Knotty Playsure twin 350xl 270 Crusaders
EDMONDS WA
Teach a boy to fish and he will go hungry supporting his boat
http://s1123.photobucket.com/albums/l550/Larrys78/
larrys@wsconline.net
g36
Post by g36 »
i used these people when i had to replace my aft tanks a couple years ago they can give you a price over the phone, give them a call
http://www.sptanks.com/webdev/home.htm
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
Post by larryeddington »
sp tanks built mine too, not installed yet but they built to my specifications and increased capacity from 100 gals to 150 gals together.
I think they were around 1500 to 1700 shipped to me.
They will cost but SP does a great job with a lot of quality.
zbigk
Post by zbigk »
Larry,
I recommend replacing the saddle tanks when you pull the engines. eventually the tanks will leak. There are 5 Trojan F32 at the boat club & every single one of them have either replaced, pupmed dry or simply removed the saddle taks. I replaced mine when i repowered (05 & 06). I have spec drawings if you need.
ZbigK
"Time Out"
Milford, CT
1982 F32 330hp MPI Crusaders
Larrys78
Post by Larrys78 »
Zbig
I would love to have the specs emal is larry.stumpf@comcast.net
EDMONDS WA
k9th
Post by k9th »
I used SP Tanks also when I replaced mine two years ago. Good quality, reasonable price, delivered on schedule. Can't ask much more than that.
Tim
"SeaDog"
1979 36' Tri-Cabin
tham57
Post by tham57 »
I killed the saddle tanks, replaced them with two fresh water tanks, had SP make two 100 Gallon aluminum tanks (Rectangle) to replace the 2 Galv. tanks in back. Worked out real well. Lost a few gallons of fuel but gained fresh water and no more inaccessible saddletank worries
