Paint Removal
Agitator
Paint Removal
Post by Agitator »
Guys,
I've began stripping the old anti-fouling paint from the the bottom of my F26.
It looks like there are 3-4 coats under there!
Sanding is proving to be quite a chore plus it's messy and I'm concerned about the helath affects of the dust. Is paint remover a better option? Is there concern about paint remover and fiberglass? Any suggestions?
Wes
Post by Wes »
Hi Agitator,
I studied the different ways of removing the bottom paint and at my age(66) I decided the best way was to have the boat yard sand blast the bottom. From what I've read there is no easy way to do it yourself. If you have the boat at home you can probably have a freelancer do it for cheaper than my yard is getting.
Wes
Agitator
Thanks Wes
Post by Agitator »
Is it possible to sandblast one without damaging the gelcoat?
What did your yard charge?
Wes
Post by Wes »
Yes. The gel coat is not harmed. In my case I need to put on 4 coats of barrier coat, a tracer coat and 2 coats of ablative after they sand blast. They are charging 37.50 a foot.
Agitator
Post by Agitator »
Thanks Wes,
Its certainly something I'll check into.
