Getting ready to remove/replace existing ones and have a couple questions. Do I drain the system (FWC) so as to not leak into exhuast during removal ?
And on installation, what gaskets are needed to seperate FWC from seawater ? And last, should I replace all bolts or reuse and where do I find a socket to fit these (12 point) ?
Crusader risers and elbows
Dennis
1989 10 Meter Mid-Cabin
Re: Crusader risers and elbows
drain down raw water and Anti-freeze, the gaskets are solid with only bolt holes maybe a weep hole on some you'll need two per side and new S/S block plates. 12 point sockets and be had at HD, Lowe's and Sears....and yes Jamie's best toy store Snap-On and I replace bolts, grade 8. NO S/S bolts....
- The Dog House
Why no S/S bolts?alexander38 wrote:drain down raw water and Anti-freeze, the gaskets are solid with only bolt holes maybe a weep hole on some you'll need two per side and new S/S block plates. 12 point sockets and be had at HD, Lowe's and Sears....and yes Jamie's best toy store Snap-On and I replace bolts, grade 8. NO S/S bolts....
Former boat: 1971 Trojan F26
Manifolds are FWC too?
S/S bolts gall when you tighten them. They tighten fine but after being the manifold and heat cycles they'll break when you go to remove them..trust me on this...
stick to grade 8
http://www.oscomotors.com/catalog/catalog17.asp
There is a description here of what you need. Note the SS shut off plate Tony mentioned. There are a few manufacturers but the parts are the same. You could also get Crusader OEM parts.
