Cockpit drains
BobCT
Cockpit drains
Post by BobCT »
I finally got around to enlarging some of the cockpit drains over the past few days. First, I went from 1" to 1.5" on each of the corner drains at the stern. New thru hulls of course. Then on the small rear hatch, I eliminated the Y connection, added a new thru hull and enlarged to 1.25". Now each corner of the hatch has a straight shot out. The deck always looked dirty under the benches because the dirty water collected there after a washdown since it didn't drain fast enough.
I want to do the same with the engine hatches but that might be on next years list.
Re: Cockpit drains
"Y" connection?
Must be different than the express due to the raised deck.
The Express has scuppers with a flap that lead directly overboard.
BobCT
Re: Cockpit drains
Post by BobCT »
Unfortunately, no scuppers on the mid cabin. All drains are connected to thru hulls. The rearmost hatch has a drain in each corner, connected together with a Y and out a single drain.
