Onan Gen Set
mak'nem
Onan Gen Set
Post by mak'nem »
Hi can anyone tell me where in Canada or for that mater the USA I can purchase a gasket set for my 1974 MCGraw Edison Onak 6.5 MCCK GenSet?
1967 seavoyager
Re: Onan Gen Set
Post by 1967 seavoyager »
Check with Cummins Diesel or Campers World. Onan is a division of Cummins.
seavoyager36@hotmail.com
"Restless"
Commissionpoint
Re: Onan Gen Set
Post by Commissionpoint »
Eh, just tie a rope around it and use it for an anchor.
Oops,sorry. What I meant to say was Onan makes a wonderful gen set. I have one also. :mrgreen:
Make sure you know your spec before you order any parts. 1974 is spec F or G I believe, but don't quote me on that. Make sure you are absolutely certain of the spec before you source parts or likely you will get the wrong stuff.
1978 F-32 "Eclipse"
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
Commander 351 Ford (PCM)
1:1 Borg Warner
Re: Onan Gen Set
Cummins in Mississauga Ontario or SMD in Orillia http://www.smdgeneratorservices.com/. Where is home port?
aaronbocknek
Re: Onan Gen Set
Post by aaronbocknek »
if you cannot locate the part (s) in ontario, here is my source in the baltimore area. they have been very helpful with the two onan 6.5 mcck's that i've owned. don't overlook the thermostats too. after that, it's time for her to get a marykate on/off acid flush to get the schmutz out of her cooling system.
http://www.cobemarine.com/
aaronbocknek@gmail.com
