Shower Curtain
Diverted Income
Shower Curtain
Post by Diverted Income »
Haven't done any searching yet but is there any trick to finding a shower curtain for an F-32? Is it just standard RV type with all those small clips?
Thanks!
1982 Trojan F-32 w/Merc 230's
1975 Baja V-1800J w/ 502 Ford
http://missriverrat.com
Nancy
Re: Shower Curtain
Post by Nancy »
You're right - the clips are an RV item. You can buy any shower curtain and cut the length as needed.
Commissionpoint
Re: Shower Curtain
Post by Commissionpoint »
I reused Nancys clips. They were still OK. I picked up 2 standard curtains from Target, transfered the clips, and rehung the new curtains. Opening the track where it splits makes it pertty fast and easy.
1978 F-32 "Eclipse"
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
Commander 351 Ford (PCM)
1:1 Borg Warner
Commissionpoint
Re: Shower Curtain
BTW. You do need 2 normal sized curtains to go all the way around. One on the sink/vanity side, and one on the door side. You will have a seam at the fwd bulkhead behind the head which will allow you to reach the shower faucet set, and another in front of the mirror on the other side. Don't go nuts with the shower head and you should have no problems keeping the water contained to the shower pan. Make sure your sump is working good too.
1978 F-32 "Eclipse"
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
1:1 Borg Warner
Diverted Income
Re: Shower Curtain
Commissionpoint wrote:BTW. You do need 2 normal sized curtains to go all the way around. One on the sink/vanity side, and one on the door side. You will have a seam at the fwd bulkhead behind the head which will allow you to reach the shower faucet set, and another in front of the mirror on the other side. Don't go nuts with the shower head and you should have no problems keeping the water contained to the shower pan. Make sure your sump is working good too.
Great. Thanks! Need to find a couple with the grommets very close to the top too, Right?
Commissionpoint
Re: Shower Curtain
Pretty close, yeah. I went with a heavier vinyl for this reason.
1978 F-32 "Eclipse"
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
1:1 Borg Warner
