What tools will I need????? Chrysler 318 1978
Well-needless to say before I bought this boat and a few years earlier-I gave away most of my tools to my son.
I just bought this 1978 F36 and one of the things the seller said was even though it ran beautiful for three days 8 hrs a day-it was due for a spark plug change and distributer and also plug wires. He said not to wait until something shows up but change before they do and he never has had a problem.
It has the air conditioner and the onboard generator. Here is what I found on some cards.
16 spark plugs-----champion X5-10y
Oil filter
Chrysler coil 2444242
Distributer 2875893.
Just some of the things.
Do these sound right?
I know I will need an oil filter wrench
I have a voltmeter
any suggestions would be appreciated.
thanks for any replies
Oil filter
I have a voltmeter
Re: What tools will I need????? Chrysler 318 1978
OK-I know I will need the usual wire cutters and strippers and screw drivers but as far as sockets?
Just get a regular socket set or maybe I need deep well set and I have a good voltmeter but what about a timing light.
How often would I need one of those. Oil filter wrench.
dfg4240
dfg4240
I would get a good reg and deep well socket set and a wrench set . a 13/16 spark plug socket . Timing light can be good to have . Normally needed when changing points and doing a tune up .
Are you sure about the engine size ? The F36 normally came with 383/400 or 440 in that year .
I have not been back to the boat since it arrived but the ad said chrysler 318's but looking at his parts cards one says
motor model M440BW19-909
serial E400723-3.
He has a big notebook folder and I am almost positive he had like new manuals saying chrysler 318.
could be a repower?
I will have to go down tomorrow -I am getting anxious to get back to the boat and clean her up
thanks
think I should get a torque wrench?
dfg4240
serial E400723-3.
could be a repower?
thanks
dfg4240
dfg4240 wrote:I have not been back to the boat since it arrived but the ad said chrysler 318's but looking at his parts cards one says
serial E400723-3.
could be a repower?
thanks
dfg4240
Ok I checked the ad and it says smooth running chrysler 318's-so it might be a repower.
Just wondering that if it is 318's then it might be a bit under powered?prowlersfish wrote:I would get a good reg and deep well socket set and a wrench set . a 13/16 spark plug socket . Timing light can be good to have . Normally needed when changing points and doing a tune up .
- Commissionpoint
Thats not a spark plug number you have there. Not sure what it is.
I just bought 3 sets. Decided to give NGK's a go for awhile with the new distributors.
NGK BPR6ES. Is what I am running in my small blocks.
1978 F-32 "Eclipse"
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
Commander 351 Ford (PCM)
1:1 Borg Warner
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
1:1 Borg Warner
I know it is not a spark plug but I think an engine number from a 440 engine.Commissionpoint wrote:Thats not a spark plug number you have there. Not sure what it is.
spark plugs he has champion X5-10y
Can you post a phot of the engine ?
- Commissionpoint
X5-10Y is not a spark plug. Champion or any other kind. Again, I have no clue what that number is in reference to. A 10 yr old BMW SUV? Perhaps. Not a Spark Plug though.dfg4240 wrote:spark plugs he has champion X5-10yCommissionpoint wrote:Thats not a spark plug number you have there. Not sure what it is.
Champions for that will be RN9YC or similar.
1978 F-32 "Eclipse"
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
1:1 Borg Warner
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
1:1 Borg Warner
Perhaps XJ-10y But this is useless unless we know the engine size . And I am betting its not a 318
- Commissionpoint
I am thinking you are probably right. 440's maybe? That would make a whole lot more sense.prowlersfish wrote: And I am betting its not a 318
1978 F-32 "Eclipse"
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
1:1 Borg Warner
Merc 305 SBC's
1.52:1 Borg Warners
1983 Correct Craft
1:1 Borg Warner
can't get to the boat until tomorrow and I will bring everything home.
thanks
thanks
[quote="prowlersfish"]Can you post a phot of the engine ?[/quote
can't until tomorrow morning- the boat is 40 minutes away.
I will post pics
I will post pics
good deal that will answers a lot of questions
