1972 F-36 Window Frame Painting
fdean396
Post by fdean396 »
I need to do some touch up painting or complete repaint of my boats exterior window frames. There are also a couple rust spots under the paint I need to address and repair. Any information on how I should prep the surfaces and also what I should use to prime and repaint the metal frames? Are the frames aluminum?
All information and assistance is greatly appreciated!
Plan B
1972 - F36
Re: 1972 F-36 Window Frame Painting
I have had good luck with Rust-Oleum marine paint on my frames ' Lowes carrys it
lawyerdave71
Post by lawyerdave71 »
prowlersfish wrote:I have had good luck with Rust-Oleum marine paint on my frames ' Lowes carrys it
+1
Captain Dave -
1978 F30 Flybridge Express
I have a similar job in progress for my F32. Started last fall but cold weather stopped me before we finished. My biggest problem this spring has been humidity - have NO interest in the mess I would end up with trying to do a final coat at 80F and 80% humidity! I can share pics when done. We are using Interlux Brighside for the paint job, and used Interprotect 2000 as the surface primer (where bare aluminum was exposed and duly sanded and solvent washed first, then immediately slathered in Interprotect before oxidation set in), with Pre Kote as the undercoat (over everything, before the Brightside got applied).
fdean396
Post by fdean396 »
Thanks for the great info and helpful tips.
Plan B
1972 - F36
Trojan26NC
Post by Trojan26NC »
I painted the window frames on the F26 using Rust-Oleum marine paint. Before I started painting I clean the surface using I think a vingegar/water solution to prep the surface if I remember right. It has been holding up well so far (three years).
1978 Trojan 26
Twin 135HP Volvo's
gettaway
Post by gettaway »
I Painted my F-32 about a year ago, I used Brightsides gloss black, primes with self etching black primer, came out nice
here is the post
http://www.trojanboats.net/wforum/viewt ... it=+frames
1984 Silverton 37C
Silver Lining
Scott
