Hi,
I would like to know the advantage of installing a 230 volt A/C over a 110 volt A/C
Thank You,
capdenny
A/C 230 or 110
Re: A/C 230 or 110
Less current draw for the same amount of work is the big one. Having a dual/split system on board has it's advantages; ie. 110v for typical loads/appliances/hardware, and 220v for items like air conditioners, stoves, etc.
Re: A/C 230 or 110
You will find most boat with 50 amp (220) shore Power use 220 volt a/c units and other large appliances .
